How many cells should I use through the thickness of the solid in a CHT (conjugate heat transfer) problem?
January 25, 2023 at 7:16 am
FAQParticipantIf the solid is just intended to transfer heat from one fluid to another one, using a resolution of 1-3 cells would be enough. If you want to capture the temperature gradient through the solid to perform some FSI calculations (or with any other purpose) then more cells will be needed. The exact number depends on the accuracy you want to obtain.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Simulating Battery Pack Cooling System Using Ansys Fluent
- How to add comments to journal file so that I will know what each entry does?
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
