Tagged: 18.1, fluent, fluid-dynamics, Modeling/Setup Advice, turbulence
August 25, 2023 at 12:16 pm
SolutionParticipantPlease see attached document for solution. Keywords: les, rans, turbulence, ns equation, eddy viscosity
1. 2050769.pdf
- Skewness in ANSYS Meshing
