Tagged: 14.5, fluent, fluid-dynamics, Modeling/Setup Advice, Species/Reactions
August 25, 2023 at 12:15 pm
FAQParticipantThe Diffusion coefficient of the SOFC module, use the default of the diffusion coefficient of FLUENT, it is calculated by the following equation: Dij,eff = (ε/τ) Dij Where Dij is the default diffusion coefficient of Fluent, ε is the porosity, τ is the bent rate. Note: Even when the SOFC module is used without the diffusion coefficient, kinetic theory and unique it is also possible to use a UDF.
1. 2043239.pdf
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
