January 25, 2023 at 7:16 am
FAQParticipantSolar Ray Tracing only tracks a ray until it reaches the first opaque wall, after this there is no more ray tracing done and with this no “real” reflection. In the boundary condition panels for walls absorptivity and (for semi-transparent walls) transmissivity has to be defined. 1 minus these values is the portion which is handled as reflected. The reflected solar flux will summed up and then distributed to the energy sources of all walls (with participation on solar ray tracing activated). This is also called as internally scattered energy. The fraction of the scattered energy which is distributed to the walls can be changed by the TUI command /define/models/radiation/solar-parameters/scattering-fraction The default value is 1 so all reflected energy is distributed. A value of 0 means all reflected energy is just taken out of the calculation.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- Simulating Battery Pack Cooling System Using Ansys Fluent
