March 17, 2023 at 8:58 am
FAQ
ParticipantQuestion: This question is related to Object Generator tool in ANSYS Meshing. Is it possible to save sequence order when creating a set of named selections, for example, a group of holes from left to right following a specific path? Answer: It is possible to enumerate boundaries in certain order if you do follow steps: 1.Create base Named Selection, е.g. inlet; 2.Use Object Generator to select «inlet» as basic item which we need to multiply; 3.Next, you need to select the first row of holes with the frame. 4.Further using Ctrl, you should also select the remaining rows from the bottom to the up part with the frame. 5. Select Scope to “Each Entity†6. Generate
- Skewness in ANSYS Meshing
