March 17, 2023 at 9:01 am
FAQParticipantANSYS Workbench itself is not licensed. It is included with most of our products including ANSYS FLUENT 12, ANSYS CFX, and ANSYS Mechanical. FLUENT 12.0 as well as 13 can be used stand alone or inside of Workbench. To utilize the full functionality of Workbench, you need additional tools such as DesignModeler, ANSYS Meshing, and CFD-Post.
