Tagged: 18.1, fluent, fluid-dynamics, General, General - FLUENT
January 25, 2023 at 7:16 am
FAQParticipantThis is a current limitation of the code that it only allows OR for checking between the convergence manager and residuals. As a workaround, you can reduce the convergence criteria for residuals and rely on monitor convergence with tighter convergence tolerance. Another option is to define a volume monitor for residuals and use it in conjunction with other monitors in the convergence manager. The caveat is you can only define a volume monitor of residual mass imbalance, but not other residuals. Keywords: monitor, residual, convergence
- Skewness in ANSYS Meshing
