June 6, 2022 at 8:33 am
FAQParticipantIn R19.2 and forward the heat release rate is stored directly in the FGM tables for post-processing. This value (in J/m3/s) is the summation over species for (H_f_j/Mw_j)*(w_dot_j) where j is the species index and w_dot_j is the volumetric rate for species j. (That is similar to the energy equation source term due to reaction).
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
