Tagged: 10.2, ensight, fluid-dynamics, General, post-processing, Visualize Data
April 5, 2023 at 2:33 pm
FAQParticipantTo generate vectors in the volume zone, you will need to do the following: 1. Right click on the volume region name > Select Load Part 2. In the pop up panel (Unstructured part builder panel) set “Element visual rep. = Full 3. click on “Load as new Part” 4. This will generate a new entry at the bottom of the parts list. 5. Right Click on this and select “Vector arrows” > select the appropriate vector variable in the Choose variable panel. 6. Click ok This will generate volumetric vectors, to colour them right click on new Vector arrow part > Colour by > Select variable.
- Rocky GPU Buying Guide
- Skewness in ANSYS Meshing
