How does the Mechanical treat a surface(s) with no thermal boundary conditions in a static or transient thermal analysis?
Tagged: 18.2, mechanical, structural-and-thermal, structural-mechanics, thermal, transient
June 5, 2023 at 7:05 am
FAQ
ParticipantAll the surfaces which do not carry any thermal boundary conditions are treated as adiabatic, so they do not exchange the heat with the ambiance.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
