How does the fatigue tool calculate the alternating equivalent stresses tool for the load combination between E1 and E2?
Tagged: 19.2, fatigue, mechanical, static, structural-and-thermal, structural-mechanics
January 25, 2023 at 7:34 am
FAQ
ParticipantAlternating stress Salt = 0.5*(E1 – E2)) and mean stress Smean = 0.5*(E1 + E2)). The stress combinations are done first on the stress components before calculating the equivalent stresses.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
