June 6, 2022 at 8:33 am
FAQParticipantI have tried to reproduce this and am getting a much larger number. After calculating the heat of reaction for C+O2 -> CO2, I am getting a significantly different value (about 9.24e7 J/kg) than the default.
Answer: The Fluent char material is c
. If this is used, along with the reference enthalpy numbers for CO2 and O2, the calculated burnout heat is consistent with the default value. Note that there are a number of forms of solid carbon. Graphite is the naturally occurring one, with a reference enthalpy of 0 J/kg. (Diamond is another.) Char is somewhat different again, and the reference enthalpy is the one that is tuned to give the observed heat of burnout for a representative coal. Some coals may be different in this respect, so we allow a change in the heat of burnout – essentially acknowledging that the coal is of a different formation than the average.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
