June 6, 2022 at 9:58 am
FAQ
ParticipantHigher contact stiffness gives less penetration which in turn gives better accuracy. But higher contact stiffness is also reflected in global coefficients matrix. Higher coefficients make the matrix more ill-conditioned. A PCG solver is sensitive to the ill-conditioned matrices. Thus it will need more iterations which in turn creates longer solution time.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
