March 17, 2023 at 9:00 am
FAQ
ParticipantFormulas for shear correction factor are found in the following references: – Schramm, U., Kitis, L., Kang, W., and Pilkey, W.D., “On the Shear Deformation Coefficient in Beam Theory”, Finite Elem in Analysis and Design, Vol. 16, 1994 – Walter Pilkey, Formulas for Stress, Strain and structural matrices, John Wiley, 1994 ANSYS determines the shear flow, and then equates the energy calculated in terms of forces-section strains to shear-stresses and shear strains. BEAM188/BEAM189 do not use higher order theories to account for variation in distribution of shear stresses. Use ANSYS solid elements if such effects must be considered. If users want a different calculation, they can use SECCONTROLS to overwrite program calculated values.
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- What is the difference between shell 63 and shell 181?
- How to use ANSYS Workbench for Merging Mesh Nodes
