March 17, 2023 at 8:59 am
FAQParticipantThe net flux crossing the symmetry plane is zero. Radiation should see a symmetric boundary as the same zero-gradient condition that other scalar fields should. “Physically”, what should be happening here is that a radiation “ray” should approach this boundary and see another just like it on the other side, so it essentially perfectly “reflects” back into the domain (or you could think of it as it actually goes out, but the other ray that it saw on the other side comes in). The net effect is no net radiative energy gain/loss through the system at these boundaries. Please refer to Section 7.3.16.2 – Calculation Procedure at Symmetry Boundaries (ANSYS Fluent User’s Guide – 2019R1) Keywords: Radiation, symmetry, Fluent
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
