June 6, 2022 at 10:32 am
FAQ
ParticipantYou need to define variables using the define command and then use the format command.
Consider the example below where two variables are defined by define command
– 1st sets the directory location and 2nd sets the file name. These variables are then used in the TUI command by using the format command.
Here the TUI command writes a mesh file to the specified directory and file name. Note ~a ~a is replaced by the variable values.
(define dir_name “/temp/box/bit/”)
(define file_name “mesh1.msh”)
(define command (format #f “file/wm ~a/~a” dir_name file_name))
(ti-menu-load-string command)
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Create Sections in Meshing
- ANSYS ICEM CFD: Basic Blocking
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is meaning of message: One or more objects may have lost some scoping attachments during the geometry update.
- What is the difference between patch dependent meshing and patch independent meshing?
