Tagged: fluent-meshing, surface-meshing, Workbench Meshing
June 6, 2022 at 10:32 am
FAQParticipantIn Fluent Meshing, there is an option to change a surface mesh made with a rectangular mesh into one made of a triangular mesh. The following steps are done in the GUI:
1. Go to Boundary > Mesh > Triangulate
2. The Triangulate Zones panel opens
3. In Boundary Zones, the area created by the rectangular mesh is displayed. Select all the areas you want to convert to triangles and click Apply
The above process makes the rectangular surface mesh a triangular surface mesh.
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS ICEM CFD: Basic Blocking
- How can I create a 2D section from a 3D model in SpaceClaim ?
- What is the difference between patch dependent meshing and patch independent meshing?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
