Tagged: 17, fluent, fluid-dynamics, LES/DES/SAS, turbulence
August 25, 2023 at 12:15 pm
SolutionParticipantPlease refer to the attached document to access the solution
1. 2043664.pdf
- Skewness in ANSYS Meshing
