How do you prevent the ANSYS Mechanical Solver producing the following errors? OMP: Error #100: Fatal system error detected. OMP: System error #22: Invalid argument forrtl: error (76): Abort trap signal
March 17, 2023 at 9:01 am
FAQParticipantOpen Mechanical Editor inside Workbench Tools/Solve Process Settings or File/Solve Process Settings For each Solve Process Setting Advanced Check/Tick Distribute Solution (if possible) Additional Command Line Arguments: -mpi ibmmpi
