How do you deal with the wall temperature name changing in the case of considering the virtual thickness?
August 25, 2023 at 12:15 pm
SolutionParticipantPlease refer to the attached document to access the Solution. This is for R15.
1. 2044966.pdf
- Skewness in ANSYS Meshing
