Tagged: 19.2, designmodeler, fluid-dynamics, General, Preprocessing: Geometry
April 5, 2023 at 2:33 pm
FAQParticipantIf you want to connect a DesignModeler geometry to a SpaceClaim geometry in Workbench you need to follow the procedure below: 1. When the SCDM geometry is ready drag and drop a new geometry component to the pjoject schematic but do not let it connect directly. 2. Then drag and drop the connection from SCDM component to the new geometry component. Choose the option “transfer default data” to transfer data. 3. “Refresh” the new geometry component. 4. Right click and choose “Edit Geometry in DesignModeler”. 5. To update the geometry import in DesignModeler click on “Generate”.
- Skewness in ANSYS Meshing
