Tagged: 19.2, ANSYS SpaceClaim DirectModeler, fluid-dynamics, General
January 25, 2023 at 7:16 am
FAQ
ParticipantShare topology tolerance can be changed from Share Topology options. There is an option – Coincidence tolerance. The default value is set to 0.1 mm. By changing this, one can change the shared topology results (especially for geometries with small clearances). This is very useful for fluids simulation, especially involving conjugate heat transfer.
- Skewness in ANSYS Meshing
