Tagged: 19, fluent, fluent-post-processing, fluid-dynamics
April 5, 2023 at 2:32 pm
FAQParticipantThe Iso clip function can clip the existing plane to the dimensions you need. Start by making a plane. Go to Postprocessing –> Surface –> Plane. Then, use Surface –> Isoclip to clip that plane. Then resulting entity can be used to calculate the reduced mass flow.
- Skewness in ANSYS Meshing
