How do I view property data tables that the Solver uses for simulation with a real gas equation of state (EOS)?
Tagged: 2021 R1, cfx, fluid-dynamics, General, General - CFX, material-properties
March 17, 2023 at 1:10 pm
Solution
ParticipantSet the expert parameter “export property tables to file = t.” At the end of the run, the solver will write the property data for a number of variables (density, specific enthalpy, specific entropy) to a set of csv files (comma delimited excel file) in the run directory. The data are presented as (X, Y, Z, Property) and can be imported into CFD-Post using File/Import for display.
1. KM834772.pdf
- Skewness in ANSYS Meshing
- ANSYS Fluent: Introduction to the GEKO Turbulence Model Part I
