Tagged: 16.1, combustion, Flamelet Models, fluent, fluid-dynamics, reaction, Species/Reactions
March 17, 2023 at 1:11 pm
SolutionParticipantThe Flamelet Generated Manifold (FGM) model is a type of Flamelet model. Unlike the Laminar Flamelet model, the reaction space of the FGM model is parameterized by Reaction Progress (and not just Strain Rate). This parameterization prevents the FGM solution from approaching chemical equilibrium (which will occur in Laminar Flamelet calculations), and allows for better predictions of non-equilibrium intermediates. The Fluent FGM model is easy to use, and the setup steps are virtually identical to those of the Laminar Flamelet model.
1. solution_2030178_FGM.pdf
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
