Tagged: fluent, fluid-dynamics, Modeling/Setup Advice, turbulence
March 17, 2023 at 1:10 pm
SolutionParticipantRun the TUI command below to use a non-Newtonian model while also using a turbulence model at the same time (i.e. use the non-Newtonian power law with the Carreau model, Cross model, or Herschel-Bulkley model): /define/models/viscous/turbulence-expert turb-non-newtonian? yes
1. 2041613.pdf
- Skewness in ANSYS Meshing
