How do I switch a boundary condition from outlet to wall and vice versa during a transient simulation?
June 6, 2022 at 8:33 am
FAQParticipantThis can be done using a workaround: Add a small additional domain downstream of the outlet, which will provide a new outlet. The previous outlet can be set to a conditional GGI interface. The opening and closing condition for the interface can be set by a logical expression. Check “Conditional Connection Control” in CFX-Pre Users Guide.
- Skewness in ANSYS Meshing
