June 5, 2023 at 7:05 am
FAQParticipantWhen you load a mesh and case file, the mesh will automatically display. For large-scale computing time or mesh large number of files, it can take time to display. If you want to stop it from displaying the mesh automatically, in the Fluent Launcher panel, removing the “Display Mesh After Reading” under Display Options.
- Skewness in ANSYS Meshing
