June 6, 2022 at 9:58 am
FAQParticipantWhen you select a beam and use the selection option ‘Beams with same profile’, it selects only beam profiles but not the beams (line bodies). To select all the line bodies with same beam profile, you can follow these steps:
1. Select a beam. Go to ‘Selection’, use option ‘Beams with same profile’
2. Right click in GUI window, select ‘Locate in Structure tree’ option
3. Check the structure tree, all the line bodies with same profile are selected
4. Right click in structure tree and select ‘Hide others’
5. Create a group for visible bodies that is line bodies with same profile.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
