Tagged: 17, fluent, fluid-dynamics, General, General - FLUENT
August 25, 2023 at 12:15 pm
FAQParticipantPlease refer to the below for the solution: /file/read-case-data filename.cas /solve/it 3000 **Constant Calculation /solve/dti 200 20 **Unsteady 200:Number of timesteps, 20:Max iteration number /file/write-case-data filename.cas **In the case of a non-steady-state calculation, set autosave in advance
1. 2041857.pdf
- Skewness in ANSYS Meshing
