How do I rotate views without knowing which way is the top view, for example in SpaceClaim Direct Modeler?
June 6, 2022 at 10:33 am
FAQParticipantWhile in 3D mode, you can use the Snap View tool, located in the Orient group on the Design tab. You can click a face to view it head-on, then click, drag, and release the mouse towards the top, bottom, or sides of the design window to ‘throw´ the face to that side. To display a straight-on view of a planar face, select the face and click Plane view in the Orient group on the Design tab.
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS ICEM CFD: Basic Blocking
- How can I create a 2D section from a 3D model in SpaceClaim ?
- What is the difference between patch dependent meshing and patch independent meshing?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
