How do I resolve the following error, which occurs when reading a mesh into CFX-Pre: Application Error in CFX-Pre: ERROR Syntax error: action ‘wbloadmesh’ parameters should have the format: param=value
Tagged: 2019 R1, cfx, fluid-dynamics, General, General - CFX
March 17, 2023 at 8:58 am
FAQParticipantThis error can occur when the Workbench project name or directory path contains a comma or other special characters. Save the project to a directory or name without these characters to resolve the error.
- Skewness in ANSYS Meshing
