June 6, 2022 at 10:32 am
FAQParticipantYou can report the mesh generation time by activating the “Report Performance Diagnostics in Messages” option in Workbench Meshing.
Go to Meshing menu, File > Options.
Click on “Miscellaneous”, under ‘Mechanical’ in the Options box.
Then, select “Yes” for “Report Performance Diagnostics in Messages”.
Now, after each mesh generation, the elapsed time will be reported in the message window.
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- ANSYS ICEM CFD: Basic Blocking
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Fluent: Watertight Geometry Meshing Workflow
- How to Fix the Error: “Mesh Exporter does not Support Overlapping Geometry in Named Selections”?
- How can I create a 2D section from a 3D model in SpaceClaim ?
