August 25, 2023 at 12:15 pm
SolutionParticipantThis isn’t automatically set up. The steps are: Set the first workflow up, and generate the report (with figures) at the end, I’d suggest saving the images too. Once that’s done close Post and save the project. Right click in the Post “Results” box, and pick properties. At the bottom of the list that pops up is an option to Publish Report tick this. Save the project again. Create the design points and run, I’d suggest saving the data for future reference. The report files and images will be E:examplespara-reportsr17p2_para-report_filesdp2PostPostReport and the images in the E:examplespara-reportsr17p2_para-report_filesdp2PostReportReport Where dp2 will be replaced with the correct design point number for each run. Sample archive is attached, note the mesh and solver settings are to create a working reporting section – the solver settings are not advised for simulations!
1. 2049270.zip
- Skewness in ANSYS Meshing
