June 6, 2022 at 10:33 am
FAQParticipantIn order to send a client an assembly model properly, you need to make sure that all your components have been internalized. Click on a component in the Structure tree with the right mouse button and select Use Internal Copy to make it internal. Finally, save your assembly and send the resulting SpaceClaim document to the client.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- ANSYS SpaceClaim: Shared Topology
- ANSYS SpaceClaim: Imprinting Geometry
- How to move component within the assembly?
- ANSYS DesignModeler: Weld Feature
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
