Licensing
Licensing
How do I obtain my Host Name and Host ID on a Windows machine?
    • FAQFAQ
      Participant
      Type in a Windows Command window: ipconfig /all and press the Enter key. Your Host Name will appear at the top, under the section Windows IP Configuration. Your Physical Address will appear under the section Ethernet adapter Local Area Connection.
