March 17, 2023 at 9:01 am
FAQParticipantAs ADMINISTRATOR, at a Windows Command Prompt, change to the directory c:windowssystem32, then type: regsvr32.exe ole32.dll regsvr32.exe atl.dll regsvr32.exe oleaut32.dll regsvr32.exe scrrun.dll regsvr32.exe wshom.ocx regsvr32.exe jscript.dll regsvr32.exe vbscript.dll Or, create a batch file regDLLs.bat ——————————-
————————— @echo on %SYSTEMROOT%system32regsvr32.exe %SYSTEMROOT%system32ole32.dll %SYSTEMROOT%system32regsvr32.exe %SYSTEMROOT%system32atl.dll %SYSTEMROOT%system32regsvr32.exe %SYSTEMROOT%system32oleaut32.dll %SYSTEMROOT%system32regsvr32.exe %SYSTEMROOT%system32scrrun.dll %SYSTEMROOT%system32regsvr32.exe %SYSTEMROOT%system32wshom.ocx %SYSTEMROOT%system32regsvr32.exe %SYSTEMROOT%system32jscript.dll %SYSTEMROOT%system32regsvr32.exe %SYSTEMROOT%system32vbscript.dll ——————————- —————————
