June 6, 2022 at 8:32 am
FAQParticipantAfter running the steady RANS analysis, enter the following TUI in the console: /solve / initialize / init-instantaneous-vel Run the calculation as it is to change the turbulence model to LES.
- Skewness in ANSYS Meshing
