How do I increase the open files limit in (Redhat) Linux? I am seeing the error “Couldn’t get hold of a new file descriptor. Too many open files” in ANSYS Licensing Interconnect or monitor.log files
Tagged: 2019 R3, descriptor, file, Installation/Licensing/Systems, licensing, limit, open, Other, ulimit, Workbench Platform - SYS
March 17, 2023 at 1:11 pm
SolutionParticipantPlease see the attached resolution document.
1. 2061829_File_Descriptor_Limit.pdf
