How do I include non-ansi functions from in compiled UDFs?
Tagged: 16, fluent, fluid-dynamics, General, General - FLUENT
March 17, 2023 at 8:58 am
FAQParticipantThe Fluent makefile uses the ‘ansi’ flag which excludes certain library functions, e.g. the error function in
. You will get a compiler warning “implicit declaration†if you try to use such a function. You will end up with a function returning int, regardless of the definition (in most cases total nonsense). You can use these functions by declaring them explicitly in your source file: double erf(double). This will lead to a useable error function (of course, it has to be defined in your library, which is platform dependent).
- Skewness in ANSYS Meshing
