March 17, 2023 at 1:11 pm
SolutionParticipantBesides the tips in solution#2000941 there are some further recommendations: Since Fluent 15, the default cycle-type in the AMG-settings for energy is F-cycle. This can improve the convergence, as shown in the attached slide 1. This is true especially for cases where diffusion is the predominant effect and for cases with high jump in thermal conductivity. However, for other cases this new default could lead to instabilities/crash. In such cases it is recommended to use the old default, which was Flexible cycle. Use Least-Square Cell-Based gradient-reconstruction method, when solving energy equation. See slides 2-4. Maybe the instability comes from ideal gas. Try to start w/o ideal gas and also w/o energy equation. Run a few iterations and then enable ideal gas. Monitor max and min values of temperature in the volume. If limiters are hit, inspect these cells by means of adapt/iso-value. If a bad mesh causes the issues, mark these cells (mark instead of adapt) and in TUI: solve/set/poor-mesh-numerics/user-defined-on-register yes, followed by the name or ID of the register. This will apply poor-mesh-numerics on these cells, even if the quality is ok.
1. Improve-Convergence-of-Energy-F-vs-Flexible.pdf
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- Simulating Battery Pack Cooling System Using Ansys Fluent
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
