June 5, 2023 at 7:05 am
FAQParticipantIt is possible to export the results of a calculation in Fluent as text data using the File->Export>Solution Data feature. After the calculation finishes, use File->Export, select Surface, and set the file type to ASCII. Then, use the Functions to Write feature to indicate the location you want to export as text data (available as cell or node data). Select the Delimiter (which specifies whether space or a comma is used as the separator), specify a file name, and click the Write button.
- Skewness in ANSYS Meshing
