Tagged: 18.2, General, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantMany result items can have their data grouped into the same table and exported, but the option to do this is hidden, since it only appears when you first right click on “Solution” and choose “Results Summary.” Then right click on “Solution” again and choose to “Export.”
