Tagged: 17.2, designmodeler, fluid-dynamics, General, geometry
June 5, 2023 at 7:05 am
FAQParticipantDesignModeler cannot be exited until it has been saved. However, since the file itself is not changed until you save the Workbench project, you can exit Workbench without saving it and return it to the last save state by opening it again. (This of course requires you to have saved the project in advance) All operations on Workbench and applications started in Workbench save their contents to a temporary folder (.Project name.backup). Files in the original project folder are not changed until the project is saved. This applies to all applications running from Workbench.
- Skewness in ANSYS Meshing
