Tagged: fluent, fluid-dynamics, General - FLUENT, Other
August 25, 2023 at 12:15 pm
Solution
ParticipantSave the calculation after the end of data, in the case of re-launched Fluent, the monitor graph as shown below can be displayed again. 1.Go to Solve->Monitor->Residuals, by clicking on Plot, you can view the residual graph. 2.To monitor another graph, go to Plot->File, ***.out that is stored in the middle of the calculation in the Add. Read the out file, you can view the monitor graph in Plot. Here, if read the .out files of different cases, you can also enable the comparison feature.
1. 2043300.pdf
- Skewness in ANSYS Meshing
