June 5, 2023 at 7:06 am
FAQParticipantPrior to R17, users had the option of setting the ASF to “off”. Now in R17.X, this is simply called the “Size Function” and “Advanced” has been omitted from the name. Setting this to “Adaptive” is equivalent to “Off” in previous releases.
- Skewness in ANSYS Meshing
