March 1, 2022 at 10:24 pm
FAQParticipantA natural or forced convection problem can be determined by using the Richardson number which is defined as the ratio of natural convection to forced convection: Ri=gβΔTL/(U_0)^2 where U_0 is the velocity of the flow [m/s] ΔT is the maximum temperature difference within the fluid region L is the representative length [m] g is the gravitational acceleration [m/s2] β=1/ρ*(∂ρ/∂T) is the volume expansion coefficient [1/K] When Ri=1, both natural and forced convection need to be considered. When Ri<<1, natural convection can be neglected When Ri>>1, forced convection can be neglected
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
