April 13, 2023 at 7:32 am
SolutionParticipantFalloff reaction rates deviate from the Arrhenius format and must be implemented using expressions/CCL. The result is a variable pre-exponential factor (A) for the reaction. Because A is dependent on Temperature, a special RULES file is required. Please see the attachments for more details
1. 2060399.pdf
2. 2060399.zip
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
