Tagged: 18, fluent, fluent-post-processing, fluid-dynamics
June 5, 2023 at 7:06 am
FAQParticipantCreate an iso-surface of “something” that will produce the line of interest when imprinted on the surface (wall). Before pressing the “Create” button, select the surface (wall) from the “From Surface” list. You now have a line on the surface of interest which will allow you to create x-y plots.
- Skewness in ANSYS Meshing
