June 5, 2023 at 7:05 am
FAQParticipantClick Help → License Usage in the main menu of Fluent to check the following license information. 1. The name of the user using the Fluent licenses 2. The name of the machine running Fluent 3. The date and time you start using the license In addition, FLEXlm is able to manage Fluent licenses and can also provide more detailed license information.
- Skewness in ANSYS Meshing
